Good, the matter is that I have a megane II, 2.0 gasoline engine, which does not turn on, that is, when pressing the button, the elaranque is activated but does not turn on. My dad went ahead and bought the gasoline pump which we changed, but nothing happens, it doesn't work. I would like to know if you have to make some kind of purge to start or if you have knowledge of a generalized failure of this car. I say it because in an occasion I spend with a Twingo that did not start and on the Internet I got the problem was a piece that lined an avioncito, I changed that and did not bother anymore.
The vehicle was presenting a fault because I was ignited, that is, the minimum went down a lot. For that reason it was that my Pope thought it was the gasoline pump.
Thanks in advance, and greetings from Caracas - Venezuela
Serial VF1BM050E5E147803.
Note: The pump is not working. that is, apparently, he is not arriving current. Well, take out the output hose or nothing comes out or anything sounds.
