Strange noise in Seai Ibiza 2006
13 years 11 months before #23852 by manual-mecanica
Strange noise in Seai Ibiza 2006 published by Manual-Mecanica
how are you.
I have a problem with my car to turn a thunder is heard on the right side as if it were on the board but already disassembled it and I do not find anything abnormal, also disassemble the spring but I do not find the cause of the noise someone who can help me please
thank you ...
13 years 11 months before #23870 by manual-mecanica
Manual-Mecanica Answer on the Re: Strange Noise in Seai Ibiza 2006
Noise is like? Is it when you turn to the right to the left? It is always or not continuous?, You checked homocetic, they are usually the cause. Explain the case a little better to help you, good luck
13 years 11 months before #23889 by manual-mecanica
If it is in fact when turning both sides and if it is continuous, it already takes it with the mechanic and tells me that the homocinetic is well.
I will have to take it with another mechanic or I don't know why the truth is no longer even
13 years 11 months before #23892 by manual-mecanica
you checked the deck of hydraulic oil, you want just that
13 years 11 months before #23893 by manual-mecanica
As you checked the homocetic the mechanic, I take out the bellows to see if they are broken or passed or looked out and nothing else
