Change of heater and return tubes
13 years 11 months before #23822 by manual-mecanica
Change of heater and return tubes published by Manual-Mecanica
Good afternoon, this morning of my Jeep Grand Cherokee of 1999, I have changed the heater and the return tubes, and does not start, exactly the pump does not reach Gasoil, so that the cylinders either.
I don't know what to do.
By the way someone has the workshop manual of that model ???? because I'm looking at but I can't find it that year.
Thank you very much.
Greetings
13 years 11 months before #23824 by manual-mecanica
Manual-Mecanica response on the re: change of heater and return tubes
That may be because you have some sleeve that goes to the chopped pump and when some air enters the pump
13 years 11 months before #23861 by manual-mecanica
If you changed tubes and did not take the air out of the system this will be your biggest problem you should bleed and now, but before this the engine started or not?
