Problem with a Kia CRDI
13 years 11 months before #23784 by manual-mecanica
Problem with a KIA CRDI published by Manual-Mecanica
What as they are just would like to know if someone can help me with a Kia Sorento 2005 CRD because I got to change an injector on the side and haora does not start and:( despite the fact that the injector has already returned to your place waiting for your answer thanks thanks:)
13 years 11 months before #23791 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with a Kia CRDI
Hi Mechanic19.
The fuel circuit of a diesel engine is not at all compatible with air, if you took out an injector you must disagree the system so that it can work normally. Luck.
Miguel
13 years 11 months before #23800 by manual-mecanica
Hello,
in CRDI you can change the injectors without fear, it is whether to purge the pipe (as it is very well recommended, just by loosening the tubes to the injectors and giving it a little boot of starting, enough ,,,,,,,, when it start
13 years 11 months before #23857 by manual-mecanica
It is more to say it but you must take the air out of the oil system, and you must review everything you did to verify that nothing is disconnected, luck
13 years 11 months before #23902 by manual-mecanica
Thank you for your help I am grabbing your tips but still without starting I am measuring the bowling that the injectors re -giving it Starter (trying to start) and according to my boltimeter it marks me 0.42 I do not know if it is fine thank you very much for your attention
