Neon 95 time setting problem
13 years 11 months before #23859 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with the time of Neon 95
The valve bending will depend on luck it is best to put the point correctly and give game, if it goes well there is no drama if not, measure compression to rule out if compression is minimum 120 psi in all cylinders the problem is another.
