problem with Ford Econoline van 1500
13 years 11 months before #23720 by manual-mecanica
problem with Ford Econoline Van 1500 published by Manual-Mecanica
Greetings to all in the forum because they will see I have an automatic Ford Econoline Model 98 1500 van, the problem is that it runs well but when I stop in a semaphor or if there is a traffic and I stand for a long time as it wants to turn off if I keep it in Drive but if I return to neutral it remains normal k it will be? I already changed the spark plugs the cables I did full service of an antifreeze tuning oil and all that will be some transmission problem or something like that help me. : UNSURE:
13 years 11 months before #23740 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with Ford Econoline Van 1500
The problem is that the revolutions are lowered with load, the solution is to raise the revolutions a bit but in neutral they are very high, do the Relay regulator service, when the vehicles are automatic over time this usually happens to them.
13 years 11 months before #23746 by manual-mecanica
Where this regulator is located and what is done about its maintenance is required to buy something
also what I wanted to comment is that it is not loaded with that fault greetings.
13 years 11 months before #23777 by manual-mecanica
No friend when he talks about loading I mean the weight that the engine does not have that the truck is loaded. This regulator is close to the admission multiple or in it has a two -pin connector, it is removed and cleaned with care with a dic vehicle.
