Well, what has been said, the radiator electromotro does not rotate. When the A/A takes a breath for a while and then begins to connect and disconnect, without putting the electro -ventilator in progress. Looking at the electrical scheme, it says that 12V arrives directly from the 37 of 50a. In this fuse they are and this is fine, but the radiator connector does not arrive. I follow the wiring, it gets inside the habitaculus towards the fuse zone but it does not go directly towards these, so I think it must pass through some section that the manual does not indicate and lose the track. I would appreciate if someone could give me any clue to solve it and thus help more people because looking through the forums seems to be a breakdown that appears a lot. Greetings.
