Help with P0A09 code
13 years 11 months before #23599 by manual-mecanica
Help with P0A09 code published by Manual-Mecanica
My 2007 Ford Diesel Party does not start and has an error code that says P0A09 DC/DC Converter Status circuit low, already look for everywhere and nothing ...
13 years 11 months before #23622 by manual-mecanica
Manual-Mecanica Response on the Re: Help with P0A09 code
If but your vehicle does not start and that code is of non -motor transmission, which is missing to leave fuel spark, more data toast
13 years 11 months before #23804 by manual-mecanica
When I put it in touch there is a relay next to the battery that bounces and there is also a solenoid in the high pressure pump that makes a Sumbido. THANK YOU
13 years 11 months before #23858 by manual-mecanica
Friend to help you well, do we need a little more data in oil or benchmaker? If it is benchmaker, does the spark or fuel lack? The start works correctly? If it is a oil company there is current in the candles? Are they in good condition?
