Too much gasoline injection
13 years 11 months before #23646 by manual-mecanica
Manual-Mecanica Response on the Re: Too much gasoline injection
Look also I know that you check the engine time since for not having a correct time the zincronization is lost, that is, the injector doses after a long time and noi in the time you have to do it
13 years 11 months before #23649 by manual-mecanica
I will take your advice, this week I have the MAF and then I will tell you what the result was.
13 years 11 months before #23659 by manual-mecanica
Look so that the oil is contaminated, nothing has to do with the sensors, but in the engine time the combustion chamber with gasoline is flooded when it opens the exhaust or admission valve tends to climb and mix with the oil, you hit the pulse of the injectors of the cables not the injectors themselves, because sometimes it happens that they saturate and are open all the time instead of closing and open, this can be checked Injectors with the vehicle walking if there is no variation are passing fuel continuously.
