ELANTRA 1.8 year 2002 The engine is parked and it does not rotate
13 years 11 months before #23571 by manual-mecanica
Greetings, I'm sorry to tell you that you are in a serious problem, the engine lost the synchronization and most likely the valve have been bent, so the engine does not rotate, the piston collides with open valves
13 years 11 months before #23573 by manual-mecanica
Thanks for the answers. I have nothing left to disarm. If any of you had any manual or CD. In disarmament it would be of great help, since sending it to a workshop for now is economically impossible to me. :( :( :(
13 years 11 months before #23582 by manual-mecanica
Friend before disarming I recommend Czechs the set -up of your vehicle, first of all, the strap of this engine is not very tense, in addition your engine uses two straps and a long one, the cut jump but turn on, they are like old cart but they turn on
13 years 11 months before #23587 by manual-mecanica
No way to disassemble you but if the synchronization points of the band are fine; I recommend you take out the oil carter lid and check the axial game of the connecting rods
13 years 11 months before #23597 by manual-mecanica
In the end today the butt
