Unstable slowdown from Daihatsu Cuore
13 years 11 months before #23554 by manual-mecanica
Manual-Mecanica Answer on the Re: Unstable idle of Daihatsu Cuore
Thanks friend but I did it as data of 1 partner and nothing happened
13 years 11 months before #23567 by manual-mecanica
Kikemec wrote: Friend in any case the computer's reset is not enough to disconnect the battery, you must also open and close the contact once the battery is connected, about three to four times at intervals of 15 to 20 seconds.
They had a good fact, that this failure happens in several cars, do it and comment, but probably the problem is in the idle valve ... IAC.
13 years 11 months before #23733 by manual-mecanica
Thank you friends, solve the problem thanks to Dirox's data.
Change the butterfly and the car I am running impeccable
thanks for the data
