Resistance in the IAT, MAP or MAF censor ..
13 years 11 months before - 13 years 11 months before #23481 by manual-mecanica
Resistance in the IAT, MAP or MAF censor .. published by Manual-Mecanica
: EVIL: : Angry: That waves, I really have very little time in this mechanics, since I am learning almost almost that I only really complicated, I always learn with my car and in this occasion I wanted to ask someone with more experience that I could guide me or tell me if I am not going to fall.
Well ... My question is that I knew that in my car there is a sensor called IAT, MAP U/O MAF honest near the multiple of admission, which tells the computer the air temperature that is entering the engine and at some point I hear that changing the caliber of the resistance of this sensor I can plot the computer causing me to deliver more power and torque.
My question is, I have a Chrysler Breeze from 96, STD, 4 CIL, Motor Dohc 2.0, 16 valves, is there any problem if this kind of modification exhausts? Since the resistance only that the engine works within the manufacturer's standards, will not ask for strength that the engine cannot deliver and will have a bit of more power and torque ...
thanks to this forum and thank its advice, to have an excellent day.
Last edition: 13 years 11 months before by .
13 years 11 months before #23501 by manual-mecanica
Manual-Mecanica response on the Re: resistance in the IAT, MAP or MAF censor ..
Having a friend have a disorder in what you are saying, the IAT is a air temperature sensor and if you truque nothing, because this sends the temperature signal to regulate initial mixture, if you truque it the best thing that can happen to you is that it starts as if it were hot and nothing else.
Now the MAP sensor measures the absolute pressure in the admission manif
13 years 11 months before #23508 by manual-mecanica
: Laugh: Ok ... Thank you very much, now I know which one is exactly, thank you very much and with respect to the IAT, is it definitely better not to do anything right? Thank you very much for your answer
13 years 11 months before #23512 by manual-mecanica
The IAT gives as the same if you leave it disconnected or notice the change, hahahaha if you want to enhance your car the best is the standard button, crossing valves or the chipeo and now.
13 years 11 months before #23513 by manual-mecanica
Thank you very much, with tips like these I learn more, thank you very much and Kreo if I put power, just put filters, spark plugs and spark plug cables ,,, I don't want to make such a considerable investment, thank you very much kike !!!! Have a good day.
