A/A fan
13 years 11 months before #23474 by manual-mecanica
A/A fan published by Manual-Mecanica
I have a 2000 megane classic, I only go the A/A fan in fourth speed
13 years 11 months before #23482 by manual-mecanica
Manual-Mecanica Response on the Re: Fan A/A
I do not know that particular car, but almost certainly are the resistances that regulate the speed and that are normally at the ventilator air outlet (because they heat). When they are cut, only the maximum PRQUE is direct works with the battery voltage.
If you take out the resistances you can weld them.
Oracior greetings
13 years 11 months before #23494 by manual-mecanica
change resistance
13 years 11 months before #23497 by manual-mecanica
It is true what the A/A fan tells you usually have a resistance with 2 or 3 derivations so that a 2 o3 steps switch chooses the speed. Check that. Although I usually go directly to the PC and look at the electrical diagram in the mitchell so I go with the points that I must check well in mind. greetings.
