He stops
13 years 11 months before #23362 by manual-mecanica
Manual-Mecanica response on the Re: stops
I recommend I recommend checking out the pressure before making another movement
13 years 11 months before #23363 by manual-mecanica
OK thanks
13 years 11 months before #23553 by manual-mecanica
Hello, I still continue with my problem, there is no case, change the benzine pump and follow the problem I leave it and stop at the key before if and sometimes I make bridge to the starting engine with the given contact and part ???????
13 years 11 months before #23580 by manual-mecanica
If you do not fix the problem of compression it is much more difficult than the starting engine since it does it with two cylinders and one in the middle, you have to repair that problem, and to give so much to the start it is broken, it is logical, it fixes well three cylinders is not enough it does not have the car.
