on
13 years 11 months before #23340 by manual-mecanica
Light published by Manual-Mecanica
I have a Renaut9 1996 it does not start, it seems that it is an electrical problem but it changes battery ditribudor bujis cable the alternator works but does not pass current to be?
13 years 11 months before #23374 by manual-mecanica
Manual-Mecanica Response on the Re: Light
But does not pass current to where? To the distributor to the coil, to the contact sheet at the start, what do you need to start?
13 years 11 months before #23384 by manual-mecanica
I recent
13 years 11 months before #23411 by manual-mecanica
If there is no sparkling sparkling cables then if it is a distributor problem but it can also be the ignition module, or coil
