SOLUTION PROBLEM
13 years 11 months before #23260 by manual-mecanica
SOLUTION PROBLEM PUBLISHED BY MANUAL-MECANICA
My Ford Fiesta 95 smokes a lot only in the games for a minute later as if nothing
13 years 11 months before #23261 by manual-mecanica
Manual-Mecanica Response on the Re: Problem Solution
What color is smoke? If it is a bit blue and only in the game after it takes temperature, it is due to the valve seals.
13 years 11 months before #23289 by manual-mecanica
Already changed sera will be the oxygen or catalytic sensor
13 years 11 months before #23291 by manual-mecanica
They may probably be rings, you should check the spark plugs, if the electrode is wet with oil if they are rings, although if you already changed valve stamps they could be the guides ????
13 years 11 months before #23294 by manual-mecanica
After hot performs a gas analysis, you send me the results and reside the precise diagnosis
