Ignition Light Insufficient Oil Pressure
13 years 11 months before #23253 by manual-mecanica
Light light pressure of insufficient oil published by manual-mecanica
Hello, I have a 306 TD with 18 years and the other day I came up with the great idea of ​​oil the engine a little because once I made this the next day when everything was normal, the oil pressure light was turned on, the stop and the temperature of the water stops and everything was normal when it turned it on again everything was normal but every 30 or 40 kilometers it again, a friend told me that it was from the sensor of the pressure of the oil. being the car has the perfect levels and the temperature of the water does not supply
13 years 11 months before #23258 by manual-mecanica
Manual-Mecanica Response On the Re: Light Light Pressure of Insufficient Oil
Something similar happens to me in the Peugeot Pertner, the same light and the stop, but oil and water temperature levels are ok and I do not know what it can be ... I have worried that theme ..
13 years 11 months before #23259 by manual-mecanica
In the case of Nikolass it seems that the issue was when cleaning the engine, I would advise you first
13 years 11 months before #23273 by manual-mecanica
And state checking the relays and there is no apparent problem but now it goes and if the battery fucks but we are not going that that was the problem at the moment has not done it to do thanks ...
13 years 11 months before #23275 by manual-mecanica
In the first case Czech the connectors of the cable
