Continuing with the previous issue (it is that if I write a letter does not let me post it) I tell you that the problem can be taken in another order of things such as:
air intake not measured by the flowmeter, (more air enters than the switchboard measures and it injects of less), detectable because it tends to stop and give sporadic failures in Lambda probe.
Lack of pressure on the injection ramp, (the same result because it is another way for the lack of feeding).
Catalizer obstructed by aggressive driving in cold or excessive urban use (if the catalyst does not reach the minimum temperature of 300ºC, it is attacked by carbonilla and if it exceeds the 900ºC, the reactive components are burned and carbonilla attacked as the catalytic reaction does not occur).
If your car carries Broadband Lambda before the catalyst and simple probe behind, the fault light is lit as a secondary lambda probe failure or catalyst failure. If this system does not carry (it only carries a Lambda probe) does not turn on breakdown but it does not throw as before.
This is due to the principle of Chaikosky that says that if they put your finger in the ... not giñas and if you do not be hungry and if you are not hungry you do not eat, because the same thing happens to the engine, if you have the escape stuck then it is construcia and do not run as before
All the best.
