Nop, Lord Fiat's step is only used on a decline to keep the release, if you have the Ford type then, so you must be very clear if it is a step by step, or an iac etc, put a photo if you do not know and answer you.
Friend, that is a step by step, if you do not have continuity it is burned and you have to change it, but try it well before because it is rare that there is no continuity in any pin, greetings.
