Peugeot 206 GTI walks in 3 cylinders
13 years 11 months before #23058 by manual-mecanica
Peugeot 206 GTI walks in 3 cylinders published by Manual-Mecanica
Will it be the coil or any bad position sensor?
13 years 11 months before #23061 by manual-mecanica
Manual-Mecanica Response on the Re: Peugeot 206 GTI walks in 3 cylinders
Well, if you were more specific in your fault, could we help you better, any fault code ???
Most likely it would be a damaged cable or the coil, I do not think that any sensor because if all the cylinders would fail.
13 years 11 months before #23072 by manual-mecanica
Peugeot 206 usually fails the coil, this does approximately at 80 thousand kilometers, this coil is complete is embedded in the spark plugs is like a spark plug ramp, but an eye can be a problem of spark plugs and nothing more, if the escapes should throw a p0300 code failure in a cylinder or fugitive current in a cylinder. luck
13 years 10 months before #23962 by manual-mecanica
:) Thanks for the fact but check it well and had some cut cables that enclose the coil and there it arranged the same thanks
