Slow motion
13 years 11 months before #23249 by manual-mecanica
Manual-Mecanica Response on the Re: Readrix
It may happen that somewhere is entering the carburetor.
13 years 11 months before #23336 by manual-mecanica
Thanks for the answers. It has two pairs of beautiful, instead of being independent, and it is not carburation. The feeding system is through injectors. The spark plugs are changed recently. Greetings
13 years 11 months before #23371 by manual-mecanica
Well, you have to focus on that cylinder that works halfway, this can be basically due to lack of fuel, due to lack of spark or a bad compression, you can send to try your coil to rule Tests, those are more less the steps to follow.
13 years 11 months before #23793 by manual-mecanica
Thank you. Why a bad compression?, Combustion chamber? Valve seat? I will have to prepare the pocket ...
13 years 11 months before #23855 by manual-mecanica
Bad compression is basically due to two factors or rings or valves, if it is a valve first, it is tested with a regulation, if it is already adjustment, but eye because the status of the cylinder head is very important, if the compression is wrong, it will not be correct, first Czech and then, depending on the result you take out the cylinder head to see surface and change packaging, it is more normal that this is to the failure more than rings or valve
