I NEED MERCEDES C220 DIESEL YEAR 1996 PORF
13 years 11 months before #22982 by manual-mecanica
Hello, someone can help me find the user and macanic manual of the Mercedes C220 Diesel also called at 202 year 1996 I need to know where their sensors are and know why the fans of the motor radiator coolers per fabor do not work for Fabor I need help from beforehand thank you very much !!!!
13 years 11 months before #22999 by manual-mecanica
Miguel The manuals are requested in the manual section, I did not move the message just because you mention a mechanical problem, now to know what is the real problem of the fans you must look Fuse, luck and greetings.
13 years 11 months before #23043 by manual-mecanica
Ok thank you very much but look in the manuals and there is not the model that I need for that I wanted to ask someone to have it ... well and as for the fans you know how much temperature would work to work these diesel engines because mine is ace between 80 and 85 degrees always I think it is fine for being diesel if Alguen knows the answer is appreciated it is a model W202 or C220 year 96 year 96
13 years 11 months before #23068 by manual-mecanica
Indeed, if the fans are activated in most vehicles a little earlier than 90 degrees, so if your vehicle does it from 80 or 85, everything is fine and within the right parameters, luck.
