BMW 318 central lock
13 years 11 months before #22949 by manual-mecanica
BMW 318 central locking published by Manual-Mecanica
Hello,
the inner lights are often lit as if there was an open door (after passing a pothole usually) and when this occurs, when closing with a key or latch, it closes but immediately reopens.
He also stopped working from the closure from the portion.
Can anyone give me any track?
Thank you so much
13 years 11 months before #22960 by manual-mecanica
Manual-Mecanica Response on the Re: central locking BMW 318
The track you give yourself, most likely you have a problem with a doors sensor, especially check the trunk, if an open door is detected the closure is reopened. The easiest way is to close the vehicle and press the doors inward and see which one turns off the light, warn and luck
13 years 11 months before #22973 by manual-mecanica
Thank you Kikemec,
as you, I think it is a problem of the door of the holder (from where the centralized does not work). I have been playing the cable mallet. They seem in good condition except one that is a bit peeled. Moving them I have managed to work for a long time. I will continue "looking to see." I have the workshop manual, to see if I find the closing sensor and its cable ...
thanks again
13 years 10 months before #24575 by manual-mecanica
I have finally found the cause of the problem ... What a nonsense !!
It was a spring plate switch that is activated with the cam the closing of the driver's door. The plate was worn. I have placed an insulating tape on top so that when you close the door, you press the little plate well and ... hand of saint.
Let's see how hard. If you wear out soon I will put a pitch.
13 years 10 months before #24606 by manual-mecanica
Jjajjaja was not so complicated friend you see, we were not so lost hahaha
