Gasoline Filter CR-V 2003 Model
13 years 11 months before #22942 by manual-mecanica
2003 Honda CR-V Model Gasoline Filter published by Manual-Mecanica
Hello: Friends of the forum I have a question I want to change the gasoline filt of a 2003 SUV Honda CR-V model and I would like to know where the gas filter is located some partner that can help me thanks
13 years 11 months before #22956 by manual-mecanica
Manual-Mecanica Response on the Re: Filter of gasoline filter CR-V Model 2003
Friend, the easiest thing is to follow the fuel line to the filter usually the slings bring it near the engine but not in all cases, identify the pipe that reaches the injection ramp and follow it back, it is the best way, if it is not on the road it is a pond filter.
13 years 11 months before #22972 by manual-mecanica
Thanks friend for your advice
13 years 11 months before #22993 by manual-mecanica
If you do not find it between the fire wall and the engine, it will bring it in the gas tank together with the gasoline and pump pressure regulator, it will be necessary to remove the element that brings all these components if you need to change it.
Greetings.
