To eat it is not a sensor but actuator, and it is called the valve or motor by step by step, in your vehicle especially you have installed iac valve of the Magnety Marely type, it is a enough one that comes out and enters an inner channel inside the admission body, this vasto has a route of approximately 8 mm, it is responsible for maintain These valves can be removed and clean two screws that affirm the body unless you have the Fire system that is a complete set included TPS, you take it clean its accommodation, disconnect the battery a minute you connect it and play 5 times to open and close the contact with a period between 15 seconds turn later and the Relay deveria deveria to stabilize, luck.
