Renault Master 2.2 dci 90 does not start hot
13 years 11 months before - 13 years 11 months before #22911 by manual-mecanica
Renault Master 2.2 dci 90 does not start hot published by manual-mecanica
Someone could tell me what is due
in cold, I don't give me any problem
this happens as long as high temperatures arrive
Last edition: 13 years 11 months before by .
13 years 11 months before #22912 by manual-mecanica
Manual-Mecanica Response on the Renault Master 2.2 DCI 90 does not start hot
Thanks to the blessed diesel that we have in our country that many do not know that 5% is diluted with biodiesel, due to cost problems, and biodiesel is deadly in Common Rail injection systems.
As your problem has already solved several cases, the high pressure pump is wearing internally and hot does not maintain the pressure you need for starting, the remains of what is detached from this is what causes you to get around or break the injectors.
Change the pump directly with the pressure regulatory valve.
greetings
13 years 11 months before #22929 by manual-mecanica
Saves would be good if they gave us a little more data since if your engine is hot diesel to leave easier than in cold, but we need noise and things like that, since I with a similar problem change the start and solve, but in other cases they have been injectors or bomb as the partner says, give us more data luck.
13 years 11 months before - 13 years 11 months before #23092 by manual-mecanica
My engine is diesel, and when summer comes because I do not know and have been in the van in progress for a while is when you stop waiting for about two hours and reset. It does not make any noise that I have noticed that the start is not at first.
13 years 11 months before #23093 by manual-mecanica
I have taken the van to a firefighter and has completely ruled out the entire injection system, it argues that it is an electrical failure and that it takes it to the remault.
And it will be what I finally do because I have taken it to several workshops and the only thing they have done so far is to get money
