Help with Astra 2002 heating
13 years 11 months before #22943 by manual-mecanica
Manual-Mecanica Response on the Rera 2002 Help Help: Help
Ok this morning, what the bulb cable recommended bridge and if the fans were actually caught the problem is the bulb?
13 years 11 months before #22945 by manual-mecanica
Oh on the other hand I inform you that if you already find the fuse block and found a few dancing but they were not much one of the whistle and another I would not be because it would not specify so that it is functioning is if someone has one diagram of the fuses and can send it to me would appreciate them.
13 years 11 months before #22959 by manual-mecanica
Indeed, if the electros set the problem, the problem is the temperature bulb, change it and now, let us see as everything is.
13 years 11 months before #22975 by manual-mecanica
How friends I tell you that the bulb does not change when the bulb cable was active as you said ok, and then it was already to remove and buy the new one and that I try once again and that they are activated normal when I reach a temperature of 80 degrees and they were activated all normal now I wonder what the problem would be I have not taken it far that they recommend me. : Blink:
13 years 11 months before #22978 by manual-mecanica
I continue with the idea that you change the bulb, but it is a bit more complicated now that it was composed, because it could be any component, the relay that is stuck, or the thermostat, but it may have been a dirt, many things change the bulb anyway, it is not expensive or difficult to change.
