Peugeot 306 TD injector?
14 years 3 days before #22808 by manual-mecanica
Peugeot 306 TD injector? Posted by manual-mecanica
Hello good afternoon, I have a Peugeot 306 1.9TD of 95 and when I started it threw a lot and made a lot of blue and white smoke that smells like diesel, it could have spoiled an injector? (The motor code is D8A) The idle is unstable, as if it didn't enter diesel into a cylinder, I wait for your help thanks.
14 years 2 days before #22837 by manual-mecanica
Manual-Mecanica Response on the Re: Peugeot 306 TD injector?
Poor the general is a symptom of injector can you take them out and clean them by sending them to check, can it also be a bomb but it always begins by the injectors, the sound of the escape is discontinuous?
14 years 2 days before #22838 by manual-mecanica
The sound of the escape is constant, but the idle seems as if he did not explode a cylinder, it is like a ta ta ta (silence) ta ta ta ta ta ta ta (silence)
14 years 1 day before #22846 by manual-mecanica
It suspects it a hahaha principle, it measures compression but it can be an injector as you say, but the black smoke appears when you walk or only in the Arranke?
14 years 1 day before #22856 by manual-mecanica
No, it's blue and white and smells like Gasoil
