I have a problem with the transmission Yaque quadado I put it in reverse rarely thunder and in the errors codes I marked p0713 p0753 p0762 p0765 if someone has any response selo would appreciate.
All the codes talk to you about the valve body, you have to check the cable harnes first and then when you no longer have the box and check the body of valves that action electrically and everything, if you do not opt for the change
