HIUNDAY ELANTRA FAULT CODES
14 years 1 week before #22673 by manual-mecanica
Manual-Mecanica Response on the Re: Hiunday Elantra Failure Codes
Hello, I checked the sensor I was damaged, I changed it and it worked well, the only thing that today in two days of proof gave me a new code (P0136) malfunction in the O2 sensor circuit (Bank 1 Sensor 2) My prewir is as I continue in this case that I must check and where it is located, thanks in advance.
14 years 1 week before #22686 by manual-mecanica
It tells you about the oxygen sensor of line one, the first exhaust outlet, and sensor two refers to the one after the Catalitical, but the little shine turned on the light?, because this vehicle not in all its veracion is mounted with two oxygen sensors, but they are those, you can also clean them if you want luck and let us know how you go.
14 years 1 week before #22694 by manual-mecanica
Hello, that code corresponds to the oxygen sensor or also called Lamda probe it must be located in the exhaust line you should check if your vehicle brings a sensor or two if one has one goes after the catalytical converter and if it has two what I do not believe it takes one before the converter and another after the converter this sensor should only change is not reusable. Special, it is causing or obstructs a gase container of the pond called canister and what it suspends is that when it covers it instead of sending the gases stored in the pond send only gasoline to the multiple of admission and therefore an exesive fuel consumption and that comes out by the escape without burning and the sensor throws it as a fault code of the sensor by the sensor by the fuel limp the container and delete the code hopefully this will help you greetings
14 years 1 day before #22845 by manual-mecanica
Thank you for the subjects 5 days ago Clean is a sensor and has not given any problem so far it works well again thanks to all for the recommendations is this case.
