Corsa ignition
14 years 1 week before #22508 by manual-mecanica
Corsa ignition published by Manual-Mecanica
I have a 4 ptas corsa. Year 96 synchronous. The problem you have is that when I turn on it sounds to me something at the start that turns but does not finish starting. I have to push it.
14 years 1 week before #22512 by manual-mecanica
Manual-Mecanica Response on the Re: Corsa Ignition
But does the combustion engine revolve? If it does not gita is the Bendix, a component that functions as a clutch inside the starting engine.
14 years 1 week before #22514 by manual-mecanica
Hello friend, as the partner says, it is most likely that he is skating the blessed of the start, you will have to disassemble it to change it, tell us how you go, greetings. :)
14 years 1 week before #22520 by manual-mecanica
For here everything, first time I register in a forum. I think it's very helpful. Regarding my problem, I will try the direct start ahead, then discard whether it is the switch, suichera or a cable because I am already worried. Thanks for the answers, I will comment when I repair it
14 years 1 week before #22566 by manual-mecanica
It is only the vendix if it turns and it is not heard that it comes out and hits then this does not succeed.
