Mechanical Fair Daewoo Leganza 2.0 of 97
14 years 1 week before #22497 by manual-mecanica
Mechanical Fair Daewoo Leganza 2.0 of 97 published by Manual-Mecanica
Hello friends, greeting everyone. I am new on this topic, and I request help to see if I can fix my car. I have a Daewoo Leganza 2.0 CDX of 97 and I have stopped it for 6 months due be a valve that is closed. It will appreciate the help you can offer me. I am also interested in the repair manual of this model. Thanks, greetings.
14 years 1 week before #22498 by manual-mecanica
Manual-Mecanica Response on the Re: Mechanical Fair Daewoo Leganza 2.0 of 97
Hello Joseapinas,
the first thing you should verify is whether there is current in the position of that cylinder, that is, if the distributor is sending signal to that spark plug, if that is fine, you must verify that the empty hose of the boster to the admission multiple is connected and in good condition and if it is not there, then try that boster. Remove the rocker lid and inspect the valve springs of the cylinder that does not work. Luck.
Miguel
14 years 1 week before #22505 by manual-mecanica
SERVILIMIT is active you have to check what is the cylinder that is not working to be able to determine because it does not, it can be something as simple as the injector is evil or something else but verifies what it is if it has a spark and if fuel reaches it, if everything is very checked the tuning to discard.
14 years 1 week before #22535 by manual-mecanica
I want to thank the answers and therefore the help offered. I'm going to do what you advise me and tell you, thanks
