Toyota diesel filter light
14 years 2 weeks before #22426 by manual-mecanica
Toyota Diesel Filter Light published by Manual-Mecanica
A Toyota was lit the light of the decanter filter and the only way to turn it off was to place the factory scanner if someone went an alternate method
14 years 1 week before #22605 by manual-mecanica
Manual-Mecanica Response on the Re: Toyota Diesel Filter Light
Friend the light of the diesel filter does not turn off with Scaner can be turned off with a procedure, but before you have to change the diesel filter for a new genuine and then you do the procedure
14 years 6 days before #22748 by manual-mecanica
I already changed the filter purchased in Toyota and now what I do
13 years 11 months before #23170 by manual-mecanica
If you are talking about the 1 KD or 2KD engine element filter you have to open the interrupter, then disconnect the 2 filter connectors you close and open the switch 3 times and then with the switch ignition you connect the two connectors and Wala the light goes out
13 years 11 months before #23471 by manual-mecanica
ok thank you very much I will rehearse
