Ford Fiesta central locking failure
14 years 2 weeks before #22393 by manual-mecanica
Ford Fiesta central locking failure published by Manual-Mecanica
I have a friend who has a 2006 Ford of 2006 approximately and when he gives command to close the closure he disrupts and closing asta that in the end this remains open because it can be ¿?
14 years 2 weeks before #22409 by manual-mecanica
Manual-Mecanica Response on the Re: Ford party central locking failure
It must check the closing regulation this leads to get the tapisado from the doors and check the regulation, now if the co -pilot side also closes all the doors that is the problem you have to leave it a slave
14 years 2 weeks before #22414 by manual-mecanica
Hello, taking into account that the door closes alone or opens, that is of the lock module is normally from the driver's door. I know why I changed a few. The Ford pecan of that. I hope to be your help.
14 years 2 weeks before #22420 by manual-mecanica
When you say check that you mean that I do not think it can be regulated or anything because it will be a piece that is closed and will only have a connector and little more? To the driver's puerda is slave
14 years 2 weeks before #22432 by manual-mecanica
They can be regulated if it is a metal abrasadera with three screws and nothing more, you release a little run the tights tight and tests until it works well, now if it is from Bombien it can be different but basically they are all the same.
