Good afternoon
I have a Plymouth Breeze Model 1998 Motor 2.0. This car is getting the green gray hair a large number of failures but little by little they were fixing. The only fault that persists is that the velocimetter does not work
on the dummy lights or the dimmer tanpoco work the rear lights do not work (the curious scheme the stops, the light of reverse and the preventive ones if they work) the nicon not so little works.
I already check all the fuses and they are fine. apparent Nente has an electrical problem. x that you already check the terminals of each device and do not reach current and check everything and do not know what to do.
Some suggestion to help me get out of this problem or one diagram of the Electric System of Post Carro, I would really appreciate your help !!!!
