The problem you have is also not explained everything, as is the temperature of the water , such as the oil pressure, the vehicle makes some strange noise of the normal, as reviewed in the electronic system if the system has a temperature error if indicated on the greeted
It is true a little data, you checked the state of the spark plugs if they are very black, some symptom is always when rolling or with a stopped vehicle also does.
