P0521 code of Honda Civis IMA (hybrid)
14 years 3 weeks before #22286 by manual-mecanica
P0521 code of Honda Civis IMA (hybrid) published by Manual-Mecanica
Friends I could help me with this code of a Honda Civic the code is a Po521 .. We already check the floods of the computer, the densor is changed and nothing the code always appears .. the scanner gives us this information at the time of checking it we have already tried from any sensor/switch pressure oil - range, operation help me please .. in advance thank you
14 years 3 weeks before #22289 by manual-mecanica
Manual-Mecanica Response on the Re: P0521 code of Honda Civis IMA (Hybrid)
www.iatn.net/techmail/summaries/2010/10/p0521-dtc.html In this address they refer to your problem and recommend changing the VTEC valve I do not know if your problem is with the oil pressure sensor of the VTEC or engine. Anyway, you can do an idea that you can do.
