Various benzine bomb.
14 years 3 weeks before #22221 by manual-mecanica
Various benzine bomb. Posted by manual-mecanica
Hello my car Chevrolet Astra 1999 Lt Mt 1.6 was changed by beaten pump and does not reach the pump
2.- Consultation direction was hard? A few days ago
3.-ELECTRICAL MANUAL OF THIS MODEL
THANKS.: Sick: : Sick:
14 years 3 weeks before #22224 by manual-mecanica
Manual-Mecanica response on the Re: Various benzine pump.
hello good evening.
The first thing is first. I would like to know why you changed the pump? for the signal or why it really bad.
To verify if you get a signal to the pump you must look for the relay of this and feed it electrically from Ahiasi you can verify the wiring.
Tell us ...
14 years 3 weeks before #22236 by manual-mecanica
Thank you for answering
: Sick: Mira stopped pulling benzina only felt like the injector threw air,
we proceed to change but does not come current
? Where is the reverse '? To change or review and learn.
14 years 3 weeks before #22273 by manual-mecanica
Deverias de Checar all the fuses first of anything if you do not reach the pump you make you reach a direct cable from sheet and now, but the address if it happened at the same time, and it is electrohydraulics, or the failure will depend the failure
