Help with lack of power in the Ford Transit 98
14 years 3 weeks before #22203 by manual-mecanica
Help with lack of power in the Ford Transit 98 published by Manual-Mecanica
I have an Ford Transit Model 98 Recove Motor has a new and new set and has no power. The ijector pump was already proven by a firefighter and says Etabien. I do not know that the lack of power will be revealed if you want to smoke from any color. Thanks
the other question is whether it has to do with the motorcycle adjustment. Tighten the cylinder cover regulation of the valves or some other adjustment.
14 years 3 weeks before #22226 by manual-mecanica
Manual-Mecanica Response on the subject Re: Help with lack of power in the Ford Transit 98
hello.
The meaning of power is to carry out mechanical work in a certain time. In a diesel engine to carry out this work there must be three fundamental conditions
1. Fuel
2 Oxygen
3. and a good compression to turn on the mixture
therefore verifies these three conditions, as you say that the pump is well verified the compression.
14 years 3 weeks before #22271 by manual-mecanica
It may happen that after an engine adjustment, the engine is tight, and this is reflected in a lack of power, the engine is sucking and does not come out as it is already very tight and it takes a bit of wear, as they do not pass from 60 or 80 kilometers per hour, it does not happen and you just have to roll it, how many kilometers do you have from the adjustment? As minimal, about 1000 kilometers are given more or less. But as I tell you it can happen and it would be normal, I don't stop
