Double Balero brand
14 years 3 weeks before #22137 by manual-mecanica
Double Balero Published by Manual-Mecanica
I need to change the double rear buller of my EcoSport 2005 What brand do you recommend? Apparently it is a common problem in this type of cars and then I would like it to last as much as possible. I appreciate your help
14 years 3 weeks before #22141 by manual-mecanica
Manual-Mecanica Answer on the Re: Double Balero brand
The double bearing is the mass bearing right? If so, seek any Japanese brand or SKF, they are the best here in Chile at least.
14 years 3 weeks before #22171 by manual-mecanica
Ok, thank you very much, they recommended that I put a good brand, but I had no idea which one was better
14 years 3 weeks before #22176 by manual-mecanica
More than the brands are the important ones, since for example Gabrial was a very good shock absorbers but now they are Mexican and is no longer the same quality of the American Gabriel. luck
