Rompeniebla Citroen C3
17 years 4 months before #2203 by manual-mecanica
Rompeniebla Citroen C3 published by Manual-Mecanica
Hello I have a C3 SX that as standard does not bring the front break but it brings the factory all the installation done, when you take out the tapas where they are placed are the ready to connect to connect. Does anyone know if you have to make any modification or connect and get ready? I have been told that they work the consecutory with a computer you have to activate the ignition tab that is the same as the rear breakblas.
Thank you very much
greetings.-
17 years 4 months before #2269 by manual-mecanica
Manual-Mecanica Response on the Re: Rompeniebla Citroen C3
Citroën carries the same system for lighting that Renault, the fuse and relays box under the steering wheel is electronic and you need to configure it to make the front fools work.
This same problem is the antinieblas of the Renault Megane for example.
Another thing you can do is wire the entire installation yourself and put the antinieblas with relay command (although the original system is always better, everything depends on what the happy configuration costs).
Greetings and I hope it is not very expensive.
