Huy is a good problem that, first of all the injectors provided them in a test bench to check that are not the problem that is, check that they are not open? The second the injectors according to their type if they load above or on the side they can have different problems, if they are of those that carry the Czech side that all the fuel seals of the injectors that are mounted in the bottom This happens is passing constant, as for the sensors you indicate there is no sensor or even the failure of all the sensors together that produce a continuous injection so large that it contaminates the oil. If this happens by aviert injectors is the cumpu and now. Fuerte and tell me about the case this type of failure is interesting.
