Auto problems (Sensors Urgent !!!!!!!!!!
14 years 1 month before - 14 years 1 month before #21986 by manual-mecanica
Auto problems Urgentee !!!!!!!!!
GOOD FRIENDS KERYA Ask a question if anyone knows what happens when a car loses power is very speaker of benzina deaceite, and in cold it works in a very uneven good way the car is a mitsubusi lancer year 1997 Motor 1.3 do some say about changing rings? I really don't know if someone can help thanks.
Latest edition: 14 years 1 month before by .
14 years 1 month before #21987 by manual-mecanica
Manual-Mecanica Answer on the Re: Auto Problems (Sensors Urgent !!!!!!!!!
Dear friend: It seems x what you put that your vehicle has compression problems, x that I recommend the following:
1 ° Do a compression test in all cylinders.
2 ° Include in the same test, the valve test. (This is with the idea of ​​knowing if they are rings or wear in valve guides)
3rd with this test to be able to rule out any other damage.
Well, I wish you luck, Slds
14 years 1 month before #21988 by manual-mecanica
14 years 1 month before #21989 by manual-mecanica
Thank you very much friend, I will try to do that and we'll see what happens ..
thanks for the jerk
14 years 1 month before #21993 by manual-mecanica
Hello, in case they have not told you even, he heats the engine for a few minutes, four or five, when the mTor slows down well, uncovered with care and without completely removing the oil filling tape It is that the engine closes badly for the segments (rings) If the noise is soft, then will be evil of vàlvules. Oil consumption is not entirely symptic, there are engines that consume a good amount and have a good performance.
