Chrysler Voyager problem helps
14 years 1 month before #21802 by manual-mecanica
Problem with Chrysler Voyager Help published by Manual-Mecanica
Hello, I would like you to help me problems
-I have the plabo and it does not start me the lights but it does not make an intention.
-I start the one in Pujon and starts
-Problema When the rodge plugs the air lights and flashes, speed account does not work pufff. The revolutions if
-The mechanic tells me that it is the sign of the clutch that leads to start but what is wrong: Sick:
14 years 1 month before #21820 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with Chrysler Voyager Help
Well, try with the switch to see if it is not damaged Czech in neutral parking sensor and tries to put the lever in neutral but I recommend you check the electrical system
14 years 1 month before #21821 by manual-mecanica
ok this fide I try it and tell you
14 years 1 month before #21828 by manual-mecanica
Giege direct, a thin cable arrives in the march. You will get a current to that cable if it does not go is your march if it cannot be your ignition pill, which recommends Oscar is good but for automatic.
14 years 1 month before #21832 by manual-mecanica
Thanks but mine is not automatic has manual change
