How to remove neon 97 crankshaft pulley?
14 years 1 month before #21765 by manual-mecanica
How to remove neon 97 crankshaft pulley? Posted by manual-mecanica
I have a problem with the distribution strap, but to change I can not remove the policy of the crankshaft, can anyone help me with the subject please?
14 years 1 month before #21773 by manual-mecanica
Manual-Mecanica response on the Re: how to remove the neon 97 crankshaft pulley?
A pulley extractor is needed that you can get it in any mechanical tools store
14 years 1 month before #21780 by manual-mecanica
That or once that you release the Damper's Sentral bolt, blow it but gently with a hammer and have a gently lever while you hit it, the best is a signature as Inge says, but try they stick and they are hard but they leave.
14 years 1 month before #21837 by manual-mecanica
I appreciate the contribution but I already tried with blows, with the extractor and it seems that this pulley there was born, they will facilitate me an extractor Act and then inform you of the result, I also send them photos of the same. THANK YOU
14 years 1 month before #21872 by manual-mecanica
hello.
The crankshaft pulleys generally prescribe, and as a smaller that costs you to take it out, but apply some liquid or compound to release graduated pieces and then a good signature and voila. If everything goes well, perform manual maintenance in the adjustment areas so that it does not happen again.
luck...
