I have a fault P0135 and P0155 possible causes
14 years 1 month before #21677 by manual-mecanica
I have a P0135 and P0155 possible causes published by Manual-Mecanica
Hello, it is the first time that I am written, I have a Mod 96 Explorer with DTC P0135 and P0155
already changed catalyst because the gasoline aroma arrived a lot at the height of the driver and spent a lot of gasoline I would appreciate your help to correct the fault Mecaneitor.B)
14 years 1 month before #21691 by manual-mecanica
Change Oxygen Sensor
14 years 1 month before #21705 by manual-mecanica
Czech empty hoses are usually strangled in that model
14 years 1 month before #21761 by manual-mecanica
That hoses and check everything and apparently it is well any other possible cause thanks for the answers I will thoroughly verify the super thanks Mecaneitor
14 years 1 month before #21763 by manual-mecanica
Thank you Kikemec and check and all hoses at first glance are well other cause already corrected the catalogors.
