Hello, if someone can help me, the time strap of my car is changed and then I remain without strength and consuming the double gasoline that I consumed before ... I think that the belt passes a pair of teeth or I do not know ... they think ... GRACIAAS FOR THE HELP ... AND IF THE CORREA IS MADE THAT HAPPENS?
Depending on how many teeth you run, you can fold valves, but do not have the engine you have no longer say it, if it is the 1.6 double camshaft engine, the k4m model, which is the same as the Clio, because this model has draft tools if you do not have them you will never be able to put it ready.
Thanks friend, today I was where the mechanic and the belt had passed 2 points, he already correct it and I will only try to see what happens ... my car is cylinder 1.4 .. Thank you for the help
