Problem with Nissan Frontier 3.5 V6 2000
14 years 2 months before #21127 by manual-mecanica
Problem with Nissan Frontier 3.5 V6 2000 Published by Manual-Mecanica
Greetings Jhovenes fix that I have a problem with my frontier, the problem is that when the revolutions are unstable, sometimes they turn off, the gasoline pump and the filter have already changed and the filter remains the same, what will it be?
14 years 2 months before #21136 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with Nissan Frontier 3.5 V6 2000
Felipe tries taking the thermostat to see how he reacts, that problem I have seen in Suzukis and it is the fault of the temperature sensor but before buying any thing there is ke Provar,
14 years 2 months before - 14 years 2 months before #21137 by manual-mecanica
Greetings Felipe, it is good to try as Kikemec comments before investing in buying sensors (which are already expensive), proves the sensor taking it to the extreme states of measure functional If you cannot take out the sensor, disconnect it and measures the resistance with the cold engine, then connect and turn the engine again until hot, turn it off and disconnect and measures, as in the previous case if there is an appreciable variation is in good condition, whether it is static or does not measure, it is necessary to replace. I hope it helps you.
Latest edition: 14 years 2 months before by .
14 years 1 month before #21436 by manual-mecanica
Solved
thanks for your suggestions, but in the end the problem was in the distributor, as a bearing has been ruined: Pinch: And the position sensor was full of metal pieces: Ohmy:, they cleaned it and changed the bearing and ready zero problems.: Woohoo:
As we say here in Guatemala Pan Pa your Matate, greetings.B)
