One of my spark plugs oil ???
14 years 2 months before #21119 by manual-mecanica
One of my spark plugs oil ??? Posted by manual-mecanica
Hello ...
I have a Mitsubishi Lancer gl 1.3 Station Wagon, Carburado, Mod 93, already a month ago and 1/2 was ringed because oil was passing in one of the spark plugs; At that time I made a long trip and arriving at my destiny I felt that my car lost strength, after reviewing it I found a wet spark plug again, so I decided to do compression tests and in Efcto it was very good 125 all. I proceeded by installing an increase and with he has worked well.
My question is that it could have happened and what consequences can bring if I still handle my car like this.
I appreciate it in advance ...
14 years 2 months before - 14 years 2 months before #21131 by manual-mecanica
Manual-Mecanica Answer on the Re: one of my spark plugs oil ???
In the first case you must ask yourself why sector enters the oil, through the cylinder head (valve seals) or, the cylinders or in its effect of the butt packing due to lack of tightening or badly mounted.
But the damage itself is in the spark plugs and the catalyst if you possess it by the high gas index (if you possess it, repair it as soon as possible since the original is very expensive) plus the presence of blue smoke between more Andes more smoke
what you should say if? 125 What?
since the pressure can be tall or low since there are several types of measure see it in your compresimeter
Latest edition: 14 years 2 months before by .
14 years 1 month before - 14 years 1 month before #21200 by manual-mecanica
Greetings!
After ringing an engine, a settlement period (filming) is necessary, as if the engine were new.
Only you and your mechanical know what the wear of the cylinder and therefore the game between cylinder and piston and the opening (GAP) of the new rings. And the procedure to ring. Amount of bunda (step in the top of the cylinder) and elimination of it.
Suppose that the car was started on that long trip after the initial heating, there were no accelerons, the level and quality of the oil were correct and drove at a moderate speed between 80 to 90 km/h.
the engine
has a damaged valve seal (s) (s). Do they work correctly? Driving a car whose engine burns oil brings economic and environmental problems.
I hope I have helped
Last edition: 14 years 1 month before by . Reason: errata
14 years 1 month before #21226 by manual-mecanica
B) Vekman the first of so many things to do, is a leaking test by cylinders like that, or where the oil is fucking to the spark plug.
14 years 1 month before #21310 by manual-mecanica
Hello, you must also remember that when an engine is recently armed the rings have to settle with the shirt and submit the engine to high revolutions.
The valves are new, the guidelines of valves? I hope you have contributed to something.
Greetings
