brakes
14 years 2 months before #21114 by manual-mecanica
Brakes posted by Manual-Mecanica
:( Very good to everyone
I tell you that I have to travel and as usual I check the brakes
change pills and the tiles restify disc and the drum changes the rubbers of the brake pump they checked the servo and everything is fine in order but at the time of curbing the pedal it is very dema hard and it costs a lot to stop went to the workshop again thinking that I had air they had air and I continue with the same problem. I already have very few days left and I have to see urgently thank you
14 years 2 months before #21115 by manual-mecanica
Manual-Mecanica Response on the Re: Brakes
Check if you do not have a break in the pipe that gives empty to the servo that puts the pedal totally hard, if it is well check the empty if you are racing the servo. You let me know if it serves you.
14 years 2 months before #21124 by manual-mecanica
Hello friend, as the fellow Whd2011 says, check the entire empty system that connects the Servofrane and its valve, greetings.:)
14 years 1 month before #21135 by manual-mecanica
It would help us that you have us, because of me it happened to me with a Peugeot that was not the servo hose if not an empty body Pekeñito that is mounted on the multiple of admission that is obstructed, you have to check everything that I have to see with empty as the classmates say, which is what is more like it to your problem.
